UCL + 1185 = crack!
ElectronGuru
Oregon
I keep reading that UCLs are fine for even high(er) power incans, so I've been trying it. About 20 continuous minutes into a run a Mag 3C with an 1185 bulb (FM holder) and UCL lens, the lens cracked. This was indoors in the tailstand configuration, so there was no rapid temp change and no shock involved. The glass is intact and even smooth to the touch:
:poof: I guess thats why all high power incans have borofloat lenses...... but this is 1st time i actualle saw a broken ucl lens :green:
often it does not have to rely on high temperature change to crack it, instead it may have arisen from a temperature difference too great for the glass to bear as the internal temperature rises beyond ambient.
I've done the same before, only mine cracked when I blew on the glass after operation. Its been Borosilicate windows for me since
When I looked closely at the pros/cons of UCL vs. Boro, I never saw the benefit of UCL in hotwires. Supposedly it has slightly higher light transmissivity, but on a practical basis I would always rather have heat durability.
Snap.
I have repeatedly recommended the use of a magnifying glass lens, but on my 2nd Mag85, I have an identical result.
RoP is the maximum for non-Borofloat, it seems.
Edit: Just thought of something else. It is possible that the UCL stands up well to radiant heat from thr bulb OK, but not to the demands of transmitted heat from a well heat-sunk head. Just a thought.
The transmissive advantage of the UCL is only 5-6% up from the borofloat so for me the small improvement isn't worth the headache. Like Lux stated, the difference in practical terms isn't perceivable to the eye, so even if you only run your mag85 for 2 minutes at a time it doesn't gain you anything and will still eventually crack.
I've been able to survive a UCL on an 1111 as part of an ongoing experiment but I've cracked a lens on an 1185 in nearly the same fashion that you did. In one intentional abuse test I had a brand new UCL last a mere two minutes on a 623. :( I knew it wouldn't last, I just didn't know how quickly it would fail. UCLs are the perfect window for LED's but I mainly leave incans to the borofloats. Using a fatter o-ring between the bezel and the lens on a mag light tends to make the a UCL last a bit longer. I guess that's because it allows for more freedom to expand and contract??? In any case it prolongs the life but still doesn't save UCLs from ultimate demise.
Might this happen to the SF 6P/9P tempered-glass bezel window while using the LF IMR-9 LA with 2 IMR 18650's?
I've used the P91+AW 18650's with no problems. Anyone know?
I had the same thing happen with a WA1111 and a multi-LED setup. A metal reflector against a UCL glass lens, possibly screwed down too tight, against an aluminum bezel, with thermal expansion, many possibilities.
Aluminum SF incans come standard with Pyrex windows. I've read some things saying they are different brand names for the same thing and others saying that borofloat is better. In any case, I've found no evidence of pyrex ever shattering.
Apparently, consumer Pyrex in the US isn't really Pyrex anymore, other than in name. But there is still some real two-phase, borosilicate Pyrex products out there (e.g., lab glassware). I would assume that SureFire's Pyrex windows are not the consumer grade, kitchen glassware from World Kitchens.
Float glass is just flat glass made by floating the molten glass on molten tin. Pilkington developed the original process. The trick is introducing the molten glass into the molten tin in a controlled fashion to avoid ripples and other surface disturbances so that the glass can solidify with two completely smooth, flat faces and with uniform thickness.
Flat glass used to be made by blowing glass and then flattening it, casting it on a flat iron surface, or rolling it between metal rollers. None of these methods produced the quality of flat glass that the float process does.
this was bound to happen, immediately after Pyrex [glass chemistry] became Pyrex™ or Pyrex® and people gets deceived when profit-motivated companies market conventional glass under the name rather than the chemistry:shakehead
Guess I am missing something here. SF uses Pyrex trademark glass, and it appears to be optical grade, maybe the same as Borofloat. Where is the deception?
Bill
Bill
Well, I wasn't referring directly to lights :)
I've had the opportunity to buy cheap cookware measuring glasses that were advertised as pyrex glass but cracked open when I washed it out with hot water after measuring crushed ice cubes for homemade ice cream.:shakehead
on the other hand...
I've ran my surefire incandescent that had pyrex windows for the duration of its cells then promptly dumped it in a bucket of ice water... other than the reflector fogging up there were no known issues with the glass, my E2e still functions like new today:whistle:
I've done that (well, cooled under a running garden hose, anyway) with my 9P+P91 with no problems at all. No cracked window, no fogging, nothing.
I've also done that with my L4 with no problems.
(Funny, I've heard that's how the Glock pistols are cooled by the testers for the Glock corporation. After enough rounds are put successively through the Glocks to make them too hot to handle, they are dumped in a water bucket, then the tests continue. No wonder I like my Glock so much!:thumbsup: )
LOL. Makes me wish I had not sold my Glock years ago. They are truly a hardy weapon.
Bill
