Ultrafire Cree Q5 -to- SSC P7 conversion
jusval
Hey,
I'm at it again. I got this small Ultrafire U4-MCU Cree Q5 flashlight, to Mod a P7 emitter into it. The light is 5" long and the head is 1 5/8" in diameter. It takes 3-AAA batteries or 1-18650. I don't have any Li-ion, so I'm using the 3-AAA even though I won't be able to push the P7 to 2800mah. I will only push about 1000mah with the Tenergy batteries I have. I'm hoping whoever buys this later, will use an 18650, so the emitter will get pushed closer to full power.
Here's a couple of pictures of the light before the mod.
Now, here's why I am using this light. It has a thick aluminum head and the Reflector is Solid. Not a thin reflector, but a solid chunk that fits snug into the head. That means it will be able to take the heat of a P7 much better. Plus it's got a glass lens.
OK, so I'm just changing out the emitter. I'm using my infamous Copper heatsink and mount for the emitter.
I'm not going to go into all the details. I took out the "pill" as shown in the photos above and I made a copper HS to replace the brass one. It's thicker than the brass one and it fits tight into the bottom of the reflector.
I mounted the P7 onto the HS and used Teflon wire and Artic Alumina adhesive. I used the original end cap over top of the HS and made a Positive contact in the center of it. I made a ground right to the HS. It all fit in the bottom of the reflector and I used thermal grease when I slid it in the reflector.
I used thermal grease on the reflector when I slid it in the head and slapped it all back together. Here's a picture of the emitter in place and the rest are Beam shots, before and after.
The beam shots aren't much. I just took a couple of shots with the camera set on Auto, in the bathroom. Yes the bathroom....
Original Q5 emitter with 3-AAA batteries.
Again, the Q5, shot at the ceiling vent.
Now the P7 with 3-AAA batteries.
and Again the P7 aimed on the vent.
Ok, so I wish I had an 18650 to see what it would look like. Already it's much brighter than the Q5. It didn't get hot at all, but I think that's because of only having the AAA batteries. 3.6v but only 1000mah.
So there it is. I will put it up for sale right away. I'm doing three different flashlights to make and put up for sale, it's the only way I can afford to get a few bucks ahead and make what I really want for myself.
Have Fun!
Justin
Is this now running direct drive? Or are you using the stock regulator?:popcorn:
I've had a couple of PM's about if I have sold this light and I have, but I sure would like to make and sell a few more. I have been thinking about doing that and doing it with regulation in the way of the KD 8x7135 board, but that doesn't give any "modes" just on/off which was what I did non-regulated. If I only stick with on/off, I don't need to put a board in.
I could possibly do it with a different board with hi/med/low, but I also know it will raise the price, so I guess I'm looking to see if you would be satisfied with just on/off or would you need to have more. I know that would end up raising the price to be able to do it.
Like I say, I really did like this mod a lot, nice small light with enough aluminum to help keep it from heating up for at least a few minutes. A low mode would help keep it getting hot at all....
What do you think?
I hope I'm not out of place posting it here.........
What do you think?
Jusval,
I'm new to the site but I've purchased several flashlights and I do have the UM-4 that you modified. There seems to be a lot of controversy about driver boards for the P7. I want to convert mine to 3-modes med, hi, lo in that order. If not, always start with medium. No memory so it always resumes to medium after its off. I know how to solder but I don't have the 'smarts' you do about electronics, etc. I wish I was an electrical engineer like some on the site. I'll wait to see if you answer this. My cell number is 562-688-1900 if you want to call.
Thanks!
Maurice
Jusval,
Thanks!
Maurice
Well, I'm not the guy to ask about electronics. I'm not educated about that stuff either. Self taught and not very good at that. For what you want, I would think asking George at www.taskled.com would be able to tell you. He's a member at CPF too. Most of the boards I find have 5 modes and I too, want only 3 modes. I hate that darned strobe stuff! I think programmable boards have the option to do that. The problem is size. The only board that I know would fit into the small area of a UM-4 would be the regular driver board from DK or KD. I haven't got dimensions on the other mode boards yet.
You probably need to post in the LED forum with the question you want answered, or just contact taskled.
Sorry I don't have the answer you need.
Justin
Would you be interested in building and selling some? If so pm me so I can set up some payment arrangements.
