I did some testing of WF-139 today too. (my charges with 340mA constant)
1. - it is overcharging to about 4,3V
2. - when the charging is complete, there is 11mA current flowing to battery. It is caused by diode and 700ohm resistor in series from charger Vin to charging output ( i think it is used to get back from protection state protected cells) I lowered it to 1mA, works the same.
3.- you can not change the cut-off voltage of this charger, because it is controlled via uC
CF9444 (only reprogramming could help).
I will use this charger only with "good protected" (with cut-off 4,2V not the 4,35V) cells.
I also have
this 1A 1x18650 charger from DX. It is better. It has constant voltahe output (my is 4,23V). When cell is empty, current is almoust 1000mA, then gradually drops until cell is full. (at 4,07V it was ~400mA).
But it is not recomended to keep cell in it long after charge is complete, because it still will be tricle charging it (some mA).
I think
this one 2x18650 will charge the same as 1 cell model.
