FlashCrazy
Just wanted to make sure that a rechargeable 3.6V Lithium RCR123 can be used in the D-Mini. I haven't seen it officially stated from Lumapower, but noticed people are. I just got a D-Mini and used a Battery Station 3.6V 900 mAH protected cell in it (Removed from another light, cell showed 3.9V). The light worked for about 30 seconds, then flickered and went out. Tried a different (same type) cell, nothing. Both cells worked in another light, no problem. Tried a new Streamlight CR123 primary cell..nothing. Smelled a slight burnt smell inside flashlight. Performed a current check, showed 2.0 amps, but no light.....ouch, not good! Removed the pill and cleaned the contacts. Reintalled and checked current....showed 460 mA, but still no light. Lumapower is going to exchange the pill, but I want to make sure I can use 3.6V cells in the future. Anyone know for sure?
