HKJ
[size=+3]Vapcell INR18650 2900mAh K29 (Purple) 2021[/size]
Official specifications:
A 18650 cell with decent capacity and current.
The two cells match nicely and can deliver the rated 20A current.
[size=+3]Conclusion[/size]
The cells looks good and can deliver a good amount of current for the capacity.
[size=+3]Notes and links[/size]
The batteries was supplied by Vapcell for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
- Model: K29
- Size: 18.3*65.2mm
- Typical Capacity: 2900mAh (0.2C discharge)
- Min capacity: 2800mAh (0.2C discharge)
- Nominal voltage: 3.60V
- Max Continuous Discharge Current: 20A
- Max Discharge Current: 35A
- End-of-charge voltage: 4.20V
- End-of-discharge Voltage: 2.5V
- Weight: 48g ( Appr)
- Internal resistance: 14mOhm ( Appr) AC 1kHz
- Standard Charge: 1500mA ,CCCV 100mA cut-off
- Quick Charge Current: 4000mA
