LilKevin715
After a emitter has heated up from a cold start, does the Vf continue to drop or does it level-off? (assuming good heatsinking)
I am asking as I've built two identical SST-50 mag's (details here) and I have gotten two different results. I've made some Vf vs time graphs for the two mags. Voltage measurements were taken every minute.
Here is the first mag. The Vf levels off at just below 3.5v, and then starts to drop after 72 minutes due to cells no longer able to maintain the proper voltage.
Here is the second mag. There is no levelling off of Vf and it continues to drop. This particular mag obviously has a higher Vf than the first one. The Vf drops faster after 80 minutes due to the cells.
Is the second mag in regulation at all? Even though the Vf isn't flat like first mag the Vf is declining at a steady rate from 34-80 minutes.
