Handlobraesing
Banned
- Joined
- Feb 14, 2006
- Messages
- 2,724
Why doesn't such a thing exist in small size? There are large restaurant refrigeration machines with a domestic water cooled condenser that simply uses water as a medium.
There are also large air conditioners that uses water, but using domestic water as a carrier and dumping it would be prohibitively expensive for something that large, so they evaporate the water and use the latent heat.
A window air conditioner is basically a box with two rooms. The back room contains a air intake/exhaust for condensing unit and the compressor and is kept outside the window. The front room has just the evaporator and the fan.
There are apartments/dormitories prohibiting the use of window air conditioners. Apartments have a water source and some dorm rooms do. Why not a ventless air conditioner that connects to the faucet, reject the heat into the water and down the drain?
Green = water flow
red = hot side
blue = cold side
It could use a few settings depending on the utility rate. If your apartment has free water, but you pay electricity, you incresae water flow to reduce temperature rise in condenser to improve BTU/kWh input. If you pay neither, reduce water flow to save water, but increase water flow when extra BTUs of cooling is needed (lower the condensing coil temperature, the better the performance)
Green = water flow
red = hot side
blue = cold side
