Hi all,
I have a WF-800 (this). It worked marvelously for a little while, but suddenly developed a vexing problem. Most often, it will start at full brightness but very quickly fade, until it becomes apparent that the fading is in fact flickering. The frequency of the flickering continues to decrease, with no bottom limit (very short duty cycle, no matter the frequency). It appears to have a 'memory' of sorts, because if the light is turned off then on again, it resumes flickering at the same frequency where it left off, but if the light is turned off for several minutes before re-lighting, it begins the cycle fresh. On top of that, on occasion it will simply flash on then go out with no fanfare.
I've taken the flashlight completely apart, down to the circuit board and nothing looked wrong. I don't have much in the way of testing equipment, other than an old analog multimeter.
I'll say this, I am a newly minted EE, so I know my way around a circuit, but have zero experience with flashlight circuits specifically. I assume the problem is in the driver, probably related to a reactive element (cap, inductor) or a component overheating.
Any help is appreciated. If it's fixable, I'd love to do that. If not, what sort of driver would you recommend (assuming that's the issue)? I'm using 2x 18650 batteries and it's running a Cree Q2 emitter, though if I change the driver I'd be more than willing to swap in a brighter emitter.
Thanks!
P.S. I'm new here, so if this is in the wrong section, many apologies.
Thanks!
