No, you can't run primaries in it. That will probably blow the circuit. They are single cell only. (I'm talking about the Jetbeam lights now)So then would it be possible to run two 123s in one of these new Jetbeams if that was all I had on hand and I didn't have a charged up 18650?
Size wise they are about as long as two CR123s and two mm thicker. Capacity wise, a single 18650 has about twice the energy of two 16340/RCR123 (rechargeable CR123s), sometimes more.I am just curious if those are like the double cr123?
Hardly special. 18650s have been used for ages in laptop battery packs and other things where energy density is more important than small size. Before they became common enough that sites like DX started selling them, the main source for hobbyists and tinkerers was, indeed, dismantled laptop packs. I've recovered a few old but still serviceable cells from discarted laptop packs myself; they usually have at least half of their cells with useable capacity left.Is the its own special form factor, so I couldn't use primaries in this light?
No. The 14500s are basically AA size lithium rechargeable cells. 18650s are much bigger and not compatable.is 18650 same as a (AA)rechargable battery
