First, I tried searching, but "4D Mag" and "4D M@g" turned up A LOT of threads that had nothing to do with the 4D specifically.
OK, now that I got that out of the way, here's basically what I want to do:
Take my incan 4D and convert it to LED.
And here are the detailed requirements: integrate a Cree or SSC LED; keep D batteries with no spacers; replace lens with glass or high-temp optical plastic.
And here's some additional "wants": Regulated multi-mode driver with high efficiency; put out up to 150 lumens; retain focusability; replace reflector with MOP aluminum; waterproofing (not immersible, just dunkable and storm-proof).
I don't know much about multi-mode drivers, but rather than add resistance to decrease light output with the drain rate staying the same I would like a driver that would increase battery life as it decreases output.
I know I could just stick in an EverLED or Terralux and call it a day, but I want to do something more hands-on. I also don't want to spend a lot of money. I know an emitter, driver, heat-sink and lens are pretty cheap and easy. What about adding an efficient multi-mode or making it focusable?
