What diameter to bore a 6P for 18650 battery?
Status
Not open for further replies.
Chevy-SS
Rhode Island
I have a small lathe, perfect for boring out my Surefire 6P body. I'm thinking of just using a 3/4" drill bit (slightly over 19mm). Is this the 'standard' size for boring out the 6P body to accept 18650 batteries?
Thanks
The one time I bored anything for an 18650 I used a 19mm drill bit. Given that the cells seem to be pushing the limits of the specs for batteries, I'd just go with 3/4" and add a wrap of something if the batteries rattle.
My 2¢.
We hit this rather comprehensively in a recent thread here:
http://www.candlepowerforums.com/vb/showthread.php?t=273798
(Remaining wall thickess considerations of the host body, diameter of different brands of 18650's, etc)
Many thanks for the link! I actually did a search and read through some threads. Didn't find that one though. Thanks again. :thumbsup:
My stock Surefire P6 appears to be ~17.5mm inside diameter. To enlarge it for a 18650, I think I will do an initial bore with a 23/32 drill bit (just purchased for $12 at Amazon), then fine tune as necessary with sandpaper on a dowel.
I did find a handy conversion chart, showing some of the relevant numbers. Hopefully this will help some:
Try a 18mm drill bit ... It will most likely leave a hole ever so slightly over 18mm , which might just be right ...
Most 18650 go 18.1 / 18.2mm , perhaps a little more , 19mm = overkill
If some one knows a good drill size to use ? A good tool place may have numbered drill bits . [ 18 / 18.1 / 18.2 etc ]
Status
