Is sunlight/daylight NW ?
I see beam shot of Quark AA2 NW and it is too yellow
Of several flash lights I owned (Cree XR-E, XP-E, Luxeon Rebel), the Rebel and a LED 6W desk light from Costco come closest to sunlight.
There seem to be many definitions of Neutral White - Some consider it to be sunlight color temperature, others consider it to be anything cooler than incans and warmer than sunlight, etc.
The best is to get the actual tint bin used in the light, i.e. a 5A tint is 4500K. Then you can compare it against other light sources, i.e. sunlight is ~5500-6000K, or a WC tint which is 6350K-7000K.
Personally I don't like dealing with terms like "Neutral" "Cool" or "Warm" - if you know the actual CCT, like "6000K", "3500K", "7000K" then you know exactly what you're dealing with.
But if it helps, Cree (the manufacturer of many LEDs) defines the following:
Cool White: 5000K-10000K
Outdoor White: 4300K-5300K
Cool White (ANSI): 5000K-8300K
Neutral White (ANSI): 3700K-5000K
Warm White (ANSI): 2600K-3700K
You can compare it to some other common light sources:
http://en.wikipedia.org/wiki/Color_temperature
