Recercare, thanks for the info on the Technisub lights.
Both Technisub and Fa&Mi are made in Italy. Both are solidly built, great products.
I got the Fa&Mi lights simply because prefer the "look" of the Fa&Mi lights. They are also a bit smaller and lighter for the same power. The specs are very similar, however. Mainly because they use the same bulbs.
The Alulight 50 uses the same lamp as the Fa&Mi 2001. The Osram HLX64610. This light is rated at 50W and 1600lm.
At maximum power, the 2001 is rated at 55 min. The Alulight 50 is rated at 50 min.
The specs are:
1) 2001: 65mm * 230mm, 1300g, 4 hour charge (intelligent), 200m WP
2) Alulight 50: 84mm * 220mm, 1450g, 5 hour charge, 100m WP
Like the 2001, the Alulight can use any compatible 12V bulb.
The Alulight 35 uses the Osram 64275, rated at 35W and 780lm. This is a G4, 6V bulb. So this would fit in the Fa&Mi RAY.
The duration for the Alulight 35 is 30 min. If the 35W bulb was used in the RAY, it would last 39 min.
The specs are:
1) RAY: 55mm * 210mm, 800g, 4 hour charge (intelligent), 200m WP
2)Alulight 35: 85mm * 195mm, 1108g, 14 hour charge, 100m WP
The Vega 100 seems the equivalent of the Fa&Mi2003. These are 12V lights like the 2001 and 2002 and the Alulight 50.
1) 2003: 104mm * 270mm, 23.3kg, 4 hour charge (intelligent), 160m WP, 55 min and110 min (with 100W and 50 W bulbs, respectively.)
2) Vega 100: 110mm * 295mm, ---, ---, 120m WP, 33 min and 70 min
The big difference between the two seems to be that the Technisubs use NiCad batteries, and the Fa&Mi's use Hydrogen NiMH (thus giving them higher capacity).
Anyway, like I said above, they are both great lights.
Kogatana, here's the info you wanted.....
The current "Big Gun" of Fa&Mi line is the 2004. It is a 24V, 4.1Ah light.
It's slightly bigger than the 2003, 107mm * 270mm, 2.4kg. So that would be 4.2in * 10.6in, and 5.28 lbs. Remember, this light is meant to be used underwater, so it uses a heavy gauge metal body. After all, It is depth certified for 160m (528 ft).
Like I metioned before, it comes with the HLX 64638 bulb which is rated at 100W and 2900lm.
You can use any compatible 24V G6.35 bulb. Here is a simple list of Osram bulbs and their run times:
1) HLX 64638, 100W, 2900lm, 60 min
1) HLX 64640, 150W, 6000lm, 36-40 min
1) HLX 64655, 250W, 10000lm, 20-24 min
Like all Fa&Mi lights, it comes with an intelligent quick charger that automatically goes into "trickle charge" mode, when the charging is finished. It will save your battery from "bad charging" effects.
Truly a monster of a light.
Another dive light manufacturer worth mentioning is the German made Kowalski lights.
http://www.taucherlampen.de/kowalen/index2.htm
They also have equivalent lights as those mentioned above (except for the 2004, of course).
Anyway, one thing that is special in the Kowalski line is that they have a HID model, called the "Speed Xenon".
I'm sure both Fa&Mi and Technisub are working on a HID model as well, which would greatly increase run time.
Of course if you really want the strongest dive light (portability not an issue), Halcyon Systems has an array of HID and HMI lighting systems for underwater. But these are very, very expensive.
http://www.halcyon.net/
This brings me to a point of interest.....
HIDs are great (bright, but longer run time), but are still too expensive. Replacement bulbs typically go into 3-digit range and sometimes 4-digits for extensive systems. In contrast, though they use much more energy, bulbs like the Osram HLX series are extremely bright and cheap. You can get them for $5-10 at a professional optics dealer (photographic, film, broadcasting equipment dealer).
To say that they are a bargain compared to HID is, at least for now, an "under-under statement".
