An object resting on a table is supported by a force equal and opposite of that exerted upon it by gravity. The 'equal and opposite' is the key - the net force is zero.
The same applies to an object in a fluid (liquid or gas). Whether an object floats or sinks, it will displace a volume of fluid equal to it's weight. This will exert a force perpendicular to gravity - the buoyant force. Whether or not this force is equal to the mass of the object determines if it will float or not. The fluid displaced by a sinking object will still exert this upward or buoyant force, it just isn't great enough to balance the force of gravity. The net force is in the favor of gravity, causing sinking.
An object cannot displace a volume of fluid with a mass greater than it's own, because this would cause the buoyant force to be greater than gravity, forcing it upwards until equilibrium is achieved. However, an object can displace a volume of fluid with a mass less than it's own - as above, this results in the object sinking.
Equal and opposite, means there is an equal force acting in the opposite direction of the original force. Even when an object is at rest forces are still acting on it, unless I am mistaken, gravity=9.8m/s^2 (at sea level) the downward force acting on everything on earth. There is a an upward force and a downward force on everything, so the net is zero, but there is still a force keeping everything from traveling to the center of the earth.
Newton's First Law states that an object will continue at rest or in motion in a straight line at constant velocity unless acted upon by an external force.
Newton's Second Law: F=M*A (net force equals mass times acceleration)
Newton's Third Law states that all forces in nature occur in pairs of forces which are equal in magnitude and opposite in direction
If you push on anything, it pushes back on you. That's why if you lean against the wall, you don't just fall through it. The wall pushes back on you as hard as you push on it, and you and the wall stay in place. Same applies to a light sitting on a table, or floating.
Definition of Buoyancy: is the
upward force that keeps things afloat.
Archimedes' principle states that a fluid will exert an upward force on an object immersed in it equal to the weight of the fluid displaced by the object.
The net upward buoyancy force is equal to the magnitude of the weight of fluid displaced by the body. This force enables the object to float or at least seem lighter.
I am getting this stuff straight out of one of my books, and notes from last semester, I was not trying to argue with anyone, just thought I would do what my professors always say, and "use the book".
I believe we are arguing the same point?
