GarageBoy
How many of these Asian companies are out there? I lost track after Fenix and Lumapower..
I mean, Olight, DeereLight, Rexlight?? Huh?
Good luck compiling an index, or even a number... Most Chinese manufacturing facilities for smaller items such as radios and flashlights require only a few thousand square feet for the entire operation, and labor is perhaps a couple dollars an hour for each of only a handful of workers. With numbers that small, even with modest output a company can make quite a profit.
That of course doesn't mean they're all the same - quality control runs the gamut from remarkable to dismal. Fenix is reknown for fantastic, durable flashlights that even see serious tactical and professional use. Then there's the barrage of no-name bargain lights, most notable for their multi-LED models in which *most* of the LEDs function at full brightness/at all.
There's definitely a new wave of Asian light manufacturers these days, but you'd be doing yourself a disservice to lump them all into one category.
did you alphabetize that in your head?
If you just mean Asian flashlight companies then Illumination's post above has most of the higher quality ones. I would add Amilite.
Well, if you mean the tube shape, then I think Fenix Started it all with their L1P.
