I have a diving flashlight with silicon o rings.</SPAN> I know I should use some substance when I screw</SPAN> the tail cap to protect the o ring.</SPAN> What should I use? Thank you
you wrote:
i'm looking for straight krytox grease that is safe for the red silicone o-rings. i do NOT want krytox 50/50 or any other blend; just the straight grease.
what doyou meen not 50/50?
did you get the GPL226?
After having a talk of the proper care and feeding of marital aids at the nearby store, I would have to say that you don't want to put silicon lubricants on silicon stuff.
Well, alot of marital aids are made of silicon, and alot of personal lubricants are also silicon, and it just dissolves things. Even the manufacturers of said devises recommend not to use silicon lube with silicon.
