NewBie
*Retired*
Handlobraesing said:Reference?
These lamps maintain 95% output after 10,000 hours.
Actually, I'm seeing a 10% drop in lumen output at 10,000 hours from multiple references, for the T8, others state an early 8% drop to 92% output from the get go, then it stays there for awhile. Example:
http://www.alliantenergy.com/docs/groups/public/documents/pub/p012398.hcsp
Rapid starting fluorescents sacrifices life:
High-performance T8 systems:
A dedicated program-start electronic ballast provides longer lamp life than standard systems. The average rated life is 30,000 hours, compared with 20,000 hours for rapid-start systems and 15,000 hours for instant-start systems.
There are some other quirks...
You can get 37,000 hours of life if you operate them 24 hours a day.
But, if the bulb spends half its time off, and half it's time on, only being turned on once a day, the life drops to 28,900 hours.
However, not all T8 bulbs are rated the same for life specs.
3 years* (7,500 hours rated life)
http://www.gelighting.com/na/home_lighting/products/fluorescent/36_inch.htm
However, there are fancier high end commercial bulbs (instead of consumer bulbs), which have higher life ratings, and better lumen maintenancee, with things like the fancy starcoat and such:
T8 Ecolux - TCLP Compliant 4' w/ Starcoat F32T8/SP30/ECO
http://genet.geappliances.com/Light...rescent&subcat=L2-49&viewcode=IDS&chkView=IDS
When looking at life on fluorescents, you have to acertain how the test was actually done. Some companies use the 3 hour on, and 3 hour off. Others use a continous 24 hours per day burn. This is very important for comparing life and lumen depreciation...
As usual, the devil is in the details.
100lm/W for T8 is for the ultra premium high end T8.
There are plenty of 74lm/W consumer grade T8 bulbs, and even more 83lm/W consumer grade bulbs.
Then you have to buy more expensive high end electronic ballast (and those also have a wide range of efficiencies). Some folks like to claim the ballasts are 100% efficient, but they aren't. LRI did some testing, and on the last report I saw, they actually ranged from 83 to 92% efficient. This lowers the lumens per watt...
Forget the low cost magnetic ballasts, especially those sold with many T8 fixtures, you loose alot of efficiency there...
Oh, and before I forget, long life bulbs often get dust, dirt, oil films, and such on them and in the non-sealed fixtures. This also causes a drop in lumen output, as well as many of the white reflector paints dim or yellow with age add in an additional lumen loss. Some companies offer high end fixtures, with very special paints, and even silicone gasketed fixtures, to seal them from dust and such. It is easy to get a 10% drop in lumens for typical fixtures in typical areas over just a 36 month period. Here are some numbers for extra clean filtered areas:
"The Figure above contrasts the new LDD function with lensed and louvered fixtures in clean conditions. It assumes better-than-average air filtration and some generated or ambient dirt. At 18 months, the LDD factor is 0.92 versus 0.84-0.85 using the traditional IESNA procedure. And at 36 months, the LDD factor is 0.89 versus 0.75-0.80."
http://www.ecmweb.com/mag/electric_designing_lighting_systems/index.html
One more thing...
Since fluorescents radiate all around them, it is usually necessary to have reflectors in most applications. It is not uncommon to see an additional 15 to 40 percent loss in lumen output due to the reflector in the fixture. Yes, you can get high efficiency fixtures, which have uber expensive coatings, but these will cost you a pretty penny. It is also not uncommon to have a diffusion grating/plastic patterned diffuser in front of the T8 fluorescent bulbs, which results in further lumen loss, which will range an additional 8 to 15% loss in lumens.
In reality, one must look at the entire picture, taking in account all the factors...
