hi,
I am looking for reflector ( about 50-60mm) for 35W car hid lamp d2r/d2s . Is it possible to buy it somewhere? I am trying to use refs from halogen lamps, but is hard to get something similary.
Regards,
m-blue
I am trying to build diving torch I have small 25-45W balast - it has diam. 50mm, so will be good find the same ref, but little bigger will be also ok.
Most 35W bulbs uses larger reflectors, well over 50mm which also have larger bulb openings and longer focal lengths. You could open up the reflector opening but you'll probably have problems with getting the correct focal length then. I don't know of any small reflectors that would with automotive HID bulbs. You might call or email EA Light and see if they'll sell you a reflector by itself but it's probably a long shot. You might have to purchase and automotive housing of some type and then modify it to fit.
