Re: Battery / charger recommendation
Howdy ES13Raven. and welcome to CPF,
For new CPF members, I always recommend reading this thread thoroughly, as it will answer 95% of your initial questions:
http://candlepowerforums.com/vb/showthread.php?t=172991
That should lead to another resource of importance if you are considering investing in some lithium-ion rechargeable batteries:
http://batteryuniversity.com/
You should read as much as you can about lithium-ion batteries
before purchasing, as they require special handling for their use and charging.
And now to actually answer your question
, I'd check out CPF member AW's offerings here:
http://www.cpfmarketplace.com/mp/showthread.php?t=170420
AW has an excellent reputation here on CPF. He has the highest quality rechargeable batteries, ships
very fast, and will take care of any problems should they occur.
If you are going to only use are RCR123 cells, then you could get his nano charger. It is quite nice, and works well. However, spend some time looking at what is available, as you might want a larger charger that is capable of also charging larger batteries in case you purchase a larger light in the future that requires them.
So, spend some time reading threads here and pretty soon you will see what will fit your needs. Have fun!
