Which side is the "+" and "-" on the Diamond dragon Led?
AlexGT
Houston, Texas
Hi all!
I recieved one of Arc Mania Diamond dragon leds (Thanks Shutter!) and have a quick question, Which side is the Positive "+" and Negative "-" on the Diamond Dragon Led emmiter?
Also can someone confirm if this led can take 1 li-ion direct drive? It has been attached with AS to a Brightlumens P7 heatsink and I don't think it will ever heat up too bad.
Thanks!
AlexGT
The side opposite the - is the + side :crackup::crackup::crackup:
just kidding, when you look at the dome the side that has a silver square is the - side. I think if you try to DD with a C Li-Ion you will toast the emitter.
Well, I just did a direct drive for a few moments with a li-ion full charge, and nope! Nothing happened exept a friggin amazingly bright light.
How much current do you think the led is getting with a direct drive li-ion?
I just tried it on a throwmaster reflector and.....
I'll post pictures soon!
AlexGT
