I haven't seen it mentioned here before, so I think it's new.
Article on it here:
http://www.ecogeek.org/content/view/1415/
Toshi
Article on it here:
Toshi
It was discussed before : https://www.candlepowerforums.com/threads/188268&highlight=luminous+efficiency
The article in New Scientist is referring to light conversion of 300 lm per watt of light not per watt of electrical input :
"The final LEDs were also better than commercially available LEDs at creating visible light, giving off more than 300 lumens of visible light for every watt of all light emitted. This figure, known as the "luminous efficacy", is high compared to typical white LEDs."
Not exactly. Try taking actual red, green, and blue LEDs and shining them on things. Most things that appear yellow for example do so by absorbing blue light. They would therefore reflect both red and green light together and the combination will still appear yellow, only with a slightly different tint or cast to it than under a broad-spectrum light. There are very few things that reflect only a narrow band of wavelengths like spectral cyan or spectral yellow, so as to appear BLACK under RGB.Note this LED produces Red Green Blue light only. Great for backlighting RGB LCD screens but in a flashlight yellow, orange cyan will show up as black.
Maybe put those tuned nano crystals on the red/green pixels instead of on the LED. It should be more efficient than phosphors.As far as backlighting RGB LCD screens, the best way to do that would be to backlight the entire screen with blue lght, then put the red and green phosphors on the red/green pixel regions, with no phoshphor on the blue regions. Right there you eliminate the majority of the filtering losses.
Agreed. Also, having the nano crystals ON the pixels, with the LCD only controlling how much blue light is used to pump each crystal, would allow for wider viewing angle than traditional LCDs, more like a CRT, which has electron phosphor directly on the screen. The biggest drawback I can think of that is that with the nanocrystals on the screen, they might actually fluoresce/react to ambient lighting.Maybe put those tuned nano crystals on the red/green pixels instead of on the LED. It should be more efficient than phosphors.
