The D10 is an example of a basic light that can handle the higher voltage offered by the Lithium Ion 14500 cell. That is the extent of the lights' development for this type of cell.Hello I just bought a nitecore D10 and it says I can use a 14500 protected cell.why does it have to be protected I have some unprotected ones what will happen if I use them
cheers
am I right in thinking its safe to use the unproteted ones in my torch as long as I dont over discharge them
Warning: It is easy to accidently turn on a D10 whilst it is in your pocket. The light will drain your cell completely and you will have an active pipe bomb in your pocket!!!:eek:we already told you, go back and read the responses. both overcharge and charge from overdischarge can be explosive.
Basically yes, I always choose protected over unprotected when ever possible. I have 6 year old unprotected AW 10440's that are still going strong and no :poof:so far. Single cell operation is much safer than multiple cell. If you follow the safety rules and buy a good charger you should be "good to go". I have numerous other AW protected and unprotected batteries and have had no problems what so ever with them.Hi thanks for the link am I right in thinking its safe to use the unproteted ones in my torch as long as I dont over discharge them
cheers
most of the people with these questions are noons who don't own a decent charger like the pila, but rather the cheapest piece of crap they could find. many of those __fire chargers don't even stop the charge, they just turn green and rely on the user to remove the cell, or the cell protection circuit to terminate the charge.This happened due to it being a multicell light running some duff unprotected batteries.
If you use an single unprotected cell carefully there is no more reason for it to explode than a protected cell. The main issue is, with a protected cell you don’t have to worry about looking after it so much. If you have a decent charger it will cut off at the correct voltage and so you don’t have to worry about overcharging an unprotected. As the man said, the D10 can be prone to switching on in your pocket though so a protected cell is probably best.
For the record, a couple of times I’ve had lights turn on in my pocket and run an unprotected cell flat with no other consequence than having to throw away the cell. Doesn’t mean it won’t happen though, just that it’s not a ‘sure thing’ it will explode like many would have you believe.
