Dukester
Not really familiar with the LRB150A cells but would an ICE/Triton work to charge them up?
Dave
Dave
vortechs said:Would the 1/2 cell extender work with any of the Wolf Eyes bodies? For instance, would two extenders on a Eagle E-3A 3-cell body allow it to use two 18650 rechargeable cells, like a E-4A?
I guess a related question would be, are the various Wolf Eyes bodies and heads compatable with each other? For instance, could someone get a E-3AX Eagle (3x 123 cell) and a M90 Rattlesnake (2x 18650 cell) then switch the heads depending on which light they wanted to be shorter on any given day?
jclarksnakes said:....For those people asking about using the extender on other Wolf Eyes lights I think the answer is probably yes so long as they can use the same tailcaps. The tailcaps are the same on my Raiders and my Rattlesnake. The Tailcap for my 2 cell Sniper is shorter and fatter and so does not interchange. This all does raise some interesting questions about using two extenders to make one of the three cell lights into a 4 cell light.
jc
Chronos said:I saw a question earlier about the LED tailcap. Will the extra 1v overdrive the LED tailcap? Should I only use the standard clickie tailcap?
All tail caps that work with the M90X will work with the M90-13V. I like to use the 9A button tail cap with my personal M90-13V because it's a little smaller but I do not recommend using the 9T tail cap (9V LED)Originally posted by vortechs
I assume the new "13V" M90 package would use the 12V LED tailcap but I would be interested to hear if could it work with the 9V one or if there are problems with using the 12V LED tailcap with the "13V" upgrade.
Mike@PTS said:All tail caps that work with the M90X will work with the M90-13V. I like to use the 9A button tail cap with my personal M90-13V because it's a little smaller but I do not recommend using the 9T tail cap (9V LED)
Ronin22 said:Thanks for the write up JC. I have a M90 13V on order so when it comes in hopefully I can get some beamshots up.
Does anyone know how I can test the lumens? Sorry, I'm not well versed in this area but would like to see if it puts out 300+ lumens as advertised.
Thanks
