NICE work!!
So you went from XM-L2 --> Nichia or Nichia --> XM-L2?
Very good stuff man. So on a scale of 1-10 (one being easiest, ten being hardest) how difficult would you say it was to do this? This'd probably be a great first mod for most people since the Xeno E03 is easy to get and doesn't break the bank and looks retry simple but is well designed.
Edit: what is the red handled tool you used to get the ring off?
I've actually not changed the emitter in this one yet. On EDCPlus you can get Cree cool white, Cree neutral white, and Nichia 219.
The cool white I got was green, so I've got a ~3000K high CRI Cree XM-L2 emitter in the mail. It's an incandescent tint, and it's beautiful in low light conditions. Looks like **** when all the room lights are on and they're not incans. I've still got the Nichia 219 stock, but I'm not as thrilled with that LED as most people are. I can't really notice the CRI difference. I think most people are actually fond of this emitter because of its neutral-warm tint, unbeknownst to them.
As far as modifications go, you're probably only going to want to do 4000K and 3000K emitters, as you can get the ~6300K cool white and ~5000K neutral white and the Nichia 219 stock. I'll be keeping my 5000K stock and the Nichia 219 stock. I'll probably end up with one of each. 3000K (mod), 4000K (mod), 5000K (stock), 6300K (mod so it's blue, not green), and Nichia 219 (stock). I like sets, especially when they don't break the bank. I'm going to try XP-G2 as well. Little throwier.
I'd give this light a 4 for ease of modification, 1 being easiest, 10 being the hardest. It's the easiest one I've encountered so far. The most difficult part is removing the stainless steel retaining ring. That's what the red-handled tool is for, but it's not ideal. That tool is called retaining ring pliers and is
sine qua non for doing any light modification. Machining a custom tool to go into all those slots would be even better. Once you get that ring off, it's a breeze. Needle nose pliers would probably be best for getting the pill out, if you don't want to grind down part of your retaining ring pliers like I have.
Yes, this light is very well built. Square threads on everything, wide voltage input range. Fundamental, basic design. Lots of metal to take up the heat. Great value. I just wish it had a factory pocket clip... maybe my next project.
