CampingLED
Have been thinking of this light for some time now. Finally some of the components are here and it is time to start sharing. A lot of work remaining though before it will be finished.
Decided to make this a modular design to make future upgrades easier than any of my other lights. Three SS bolts will be used to hold the parts together and no glue will be used. Optics or emitter swaps will only require the loosening of the bolts and some soldering. Heat conductive past will be used between all metal parts and the star to body coupling. The lens will press against the optics that will in turn keep pressure on the Triple R5 star. All other components will be added externally to make future upgrades easy.
The driver circuit will be similar to the ones that StefanFS uses for his P7 Mag mods (8 x 7135 multi-mode driver). I have enough 7135 driver boards, but still waiting for delivery of the multi-mode one that will piggy back to the other board. Therefore three mode with Max 2800mA. Three XP-Gs will be wired in parallel. Will either use one or two 18650 batteries.
Still need to work on the coupling between the head and the headband of this light as well as the other external components.
Here is a picture of the main components that I have right now:
I asked a friend of mine to machine the aluminum parts for me before he left his company. He was so busy and left it with a colleague. Took a long time before he made it and he decided not to charge me. The machining is not as perfect as I wanted it, but with some extra work it will be fine.
Partial dry fit
Dry fit
If this works well I may just make a few more.
Partial dry fit
Dry fit
