thedoc007
My SC62w will take everything from flat tops at ~65mm to the Eagletacs a bit over 69mm. The spring will just compress tighter, but it's still not a struggle to get the cap on.
I've only seen the Eagletacs listed as 68.3 mm - making them the shortest (3400 mAh) protected cells in existence, as far as I know.
In any case, I forget who, but someone recently told me that some new Keeppowers wouldn't fit in their SC62 (diameter was the problem, not length). Given the Xtar cells are among the very widest 18650s I have, I would be a little more concerned about the width, as opposed to the length. It isn't just a matter of compressing a spring more...the metal walls aren't gonna give. Really you want at least a small amount of play...otherwise you might damage the wrapper as you insert or remove the cell.
