@LED Monkey is right.
Actually there is a very small deviation in the cut-off voltage of all chargers. The cut-off voltage of VC8 is 4.2V±0.05V. As the battery also has an internal resistance of about 100 milliohms, so the battery voltage after charging is generally about 4.15V. And after a long-time use, the internal resistance is large, so the battery voltage will be low.
For the charging rate, the current coming from the input port is actually evenly distributed to each slot after put batteries in. The constant current of VC8 is 3A*1, 2A*2, 1A*4, 0.5A*8. When the battery is about to be fully charged, the VC8 will automatically reduce the distributed current to ensure the safety of the later charging and fully charge the battery as much as possible.
In addition, if the battery resistance is too large, the VC8 system will initiate protection measures to automatically reduce the charging current.
As for the charging adapter, I tried a Samsung adapter and a usb charging cable, both can power VC8.
Please change different charging cable to test whether the original cable has any problem.
If it is still not solved, maybe you can post your adapter spec or the process pics to see if there is any other problems.
