Hot photo tip: Install Picasa and use the "fill light" slider to improve the "exposure" of a point & shoot.
Here is a copy of that same picture with fill light around 75%, and color temperature around 30%:
No, it's primarily an exposure issue, and secondarily color balance. I bumped the fill light higher than I normally would for contrast to the original. There is only so much that a filter can do to fix a picture that was underexposed in the first place. But it's one of the best 5-second fixes I know.The only thing wrong with the original is the colour balance due to the artificial lighting, your version looks washed out to me.
Great question. :thumbsup:
Doing the math...193 lumen max output of the SC50 requires 3-4 watts of power from the cell.
Looking at the different cell chemistries...
-- Alkaline AA cannot deliver 3-4 watts, sorry.
-- Lithium AA can deliver a brief burst of 3 watts, e.g. for a camera flash, but not continuous.
-- NiMH AAs can deliver 3-4 watts continuous, albeit with a shortened runtime.
-- Lithium-ion 14500s can also deliver 3-4 watts continuous.
Unfortunately the electronics cannot tell if you are using alkaline, lithium. or nimh cells. The voltage is about the same for all of these chemistries. So apparently zebralight set a max boost-mode output that would work with all of these chemistries.
It would be sweet if there was some secret-handshake clicky sequence to enable the max output mode for NiMH cells. Zebralight?
-Jeff
Hi Zebra,
I have the sc50 running on AA NiMH batts. when the bats get low, say around 1.05V the light will not come one. Not even in low. Is this normal? thx
If the sc50 has a buck-boost converter, why do you get higher lumen output with the 14500 cells compared to NiMH/Alkaline? Does the micro measure the cell voltage, see it > 2v and use higher current and voltage cut-off settings? Otherwise you should be able to drive the same currents through the diode regardless of cell chemistry, but I guess you'd want to cut off lithium ion cells at a much higher voltage than the other chemistries. What is the reasoning between using different drive currents though?
I'm really interested in the sc50w, it sounds like a great little light. I was just hoping for more output without investing in new cells.
Is anyone turning the SC50 on accidentally in the pocket? Still trying to decide to buy one or not and if the switch is a problem in the pocket I'm not interested but if it is generally not a problem I'm in.
I have the SC30W.
All that needs to be done to avoid accidental activation is to unscrew the Tailcap 1/8th of a turn to lock it out. Not a big deal at all IMO.
That means unscrewing and rescrewing it every time it gets removed from and put into the pocket which would be a pain if you use it frequently.
+1There's a reason there are so many lights available with so many different features and UI's...to give users options.
Imagine how boring flashlights would be if they all featured the same UI's, switches and programing...:sick2::thumbsdow
There are very few lights (if any) that do everything perfect.
For the price point and what these light have to offer, I feel they are a bargain and built VERY well!
Unlike the H501, the circuit in the SC50 is a full blown buck-boost converter (actually, two independent converters that can fully support 14500's while still maintaining extremely high efficiency in the boost mode).
I just tried a little test: unscrew the tailcap like a 1/16th or less and it locks it out from accidental activation.
If you're after the slimmest light available in AA it will be the EZAA which I carry next to my wallet in my back pocket, but the MiNi will definitely beat it for your close up work. My two favorite AA lights are the EZAAw and MiNi AA!Thank you for posting this picture. I have not ruled out the Mini AA yet because its all-around slender round shape is ideal for the way I intent to carry the light. Also, the big hot spot from the XP-G emitter is ideal for close-up work, which I often use my lights for. What is your opinion of these lights?
By the way, accidental activation can be minimized by designing a smaller and more recessed click button.
From what I've seen, no one does heat management (sinking & transfer) in a AA light as well as Zebralight.Do you have a SC50? I am dying to know how the SC50 compares to the Mini AA and to the Akoray 106 when using 14500 battery.
