Yes, I'm old and wear glasses
But, I don't believe that the 10-degree hot-spot from our SC600's will be very helpful reading numbers on a house that is 150 to 200 yards away after the nearby wall-of-light has caused my
pupil to choak down and reduce my night vision. Be real. With my bad eyesight and all; I have trouble reading house numbers that are more than 25 yards from the street using my 750 lumen SC600. But, I can read them easily using my old 200 lumen oLight T20-Q5 because it throws better and the side-spill isn't so overwhelming.
P.S. my "only good for 10 yards" was a little harsh; sorry. IMHO, I can read house numbers and search effectively out to 20 yards with my SC600.
I did some measurements, and the side spill shutting down the pupils is not so much the factor as the lumens being more concentrated, thus producing more lux on target.
Apparently, from what my meters, etc, and eyes, are telling me, is that if the 200 lumens is concentrated onto a patch of small surface area, that area will be more brightly lit/easier to discern details of, than the light from a 750 lumen light that is covering a much larger surface area.
So, if I spread out my 750 lumens over a large area, each lumen is spread thinner, and, the LUX produced is proportionally lower. (We SEE Lux, we do NOT see lumens...).
This is why I can get a brighter lux reading on a distant target with a crappy 131 lumen LED maglite than with a 750 lumen SC600, etc.
By the time the lumens HIT the target, if I use a shotgun analogy...the maglite pattern is super tight, and all the lumens whack the small target, so I get almost all of the 131 lumens being turned to lux.
The SC600 pattern is like a sawed off shotgun, for a distant target, the llumens are so scattered in such a large pattern, that only a few of the original 750 actually HIT the target, and, therefore, only a few of them get turned to lux.
If ENOUGH lumens get turned to lux, you CAN read that house number....if not, well, you need to shoot at it from a closer range/use a different choked light, etc.
The aspheric lensed lights are more like sniper rifles in this regard....SUPER small patch of light, BUT, ALL the lumens hit the target (Hitting it in the shape of the LED)
So, its not so much that spill ruins night vision...what you are FOCUSED on controls your pupil dilation (Hence how you look for a concussion, etc, with a flashlight...the pupils contract differently under these scenarios...)
In other words, If I used the aspheric to project a tight beam onto a distant target sufficiently for you to see the house number, with zero spill...and you are looking AT those numbers...you will STILL see them even if I ALSO turn on the SC600. The added peripheral light didn't make the lux on target needed change. (I tried it, it works).
I think the impression was given by the lights that were available back when impressions were being formed. Almost all lights had tight beams, as they produced, compared to today's lights, almost no lumens...and HAD TO concentrate everything as tightly as they could to SEE anything anyway.
When competitive lights came out with more floody beams, people would notice that even though the lights were "brighter", they could see distant details better with the more concentrated albeit lower lumen beams.
Once an opinion like this forms, and gets "taught" as dogma....well, its all but impossible for facts to intervene.
Obviously, its all a question of DEGREE, but, all things being equal...the concentration of the available lumens will play a much larger role than the amount of spill per se.
