snowdriver
It's kind of hard to describe, you should have been there
Spinning the battery out was the solution. I glued an old alkaline battery on the top of the stuck 14500 and then carefully spinned it out.
But even though I love the light I keep having a hard time with it. All of my 3 new EagleTac 14500s do not work in the light. It just doesn't turn on. Only with Eneloops and Alkalines. Also the 14500s keep getting stuck. But I have developed a more efficient technique to get them out: i smash my hand with the light in it on the side of my couch and then the 14500 comes out with a *plop*. The 14500s go into the light smoothly until the last few milimeters, then i have to push harder and thats when the batteries get stuck. As it happens with all 3 new batteries i'm guessing it is a problem of the light?
I think i will have to send the light back as working with 14500s was one of its main purposes. I guess this was just bad luck.
thanks to everyone for the kind help.
If i look closely at the eagletac picture it looks like there is subtle round lip at the top and the bottom.
$65 light + more for batteries and you have to slam it against the couch to get the batteries out? I would just stick to Enerloops.
Unless of course, using glue, magnets, and slamming techniques makes the flashlight experience more pleasurable...
I'd imagine the same reason why AAA Eneloops are labeled with 800mAh typical, 750mAh minimum.Ugh....... I just received four new KeepPower 800mAh's and they don't fit my SC52 or S10 Baton...dangit.... Let me tell you guys a story......my son was "helping me" and installed one of the new 800mAh KP's into the SC52 and got it stuck... I couldn't get it out so I had to use drastic measures.. I drilled a small hole into the end of my new battery.. and pulled it out... Well, I already ruined the battery so I figured I would dissect it. I peeled the black shrink wrap off to expose the blue shrink wrapping, two coats of wrapping..no wonder it won't fit but anyway.... What I found next written on the blue wrapping was interesting... "ICR14500 3.7V 750mAh PRM"...... :shrug: Does the protection circuit on the end of the batt mysteriously add 50mAh's the the 750mAh battery or what ?? :thinking:
Two words: unprotected battery.
