I just got a modified arc 4+ - original switch, modified led. The switch feels fine. The light is new to me. The SOS option does not seem to be working properly. When I go to the SOS option - the light blinks 3 times - long blinks (the letter o), then blinks 3 more times even LONGER (or I mean to say SLOWER) if I let it continue. If I select this option by holding down the button - that is what it continues to do - blinks 3 times long, then pulsates at a very dim level instead of blinking the 3 short times (the letter S). All of the other options behave in the same way. For instance, the switch lock function blinks 2 short blinks in the options menu, but between those 2 short blinks, the led stays lit and pulsates very dimly, just as in the SOS mode. It behaves like this in all modes. Like I said the switch feels OK, I feel a millimeter or so of play in it when pushing it in and the contact feels solid when I press it in. I am wondering if this a contact problem, a battery problem (I am using rcr123a), or maybe a processor problem, or maybe I am simply doing something wrong. All of the brightness levels preform perfectly. The led is a very white & bright U bin. Any comments appreciated....thanks
-panflute
-panflute
