A toilet scrub, a vase and a few leds...
PEU
Buenos Aires / Argentina (I like ribs)
What happens when you mix:
A toilet scrub:
scrub
and a vase:
vase
I hope you didn't bet on this art deco artifact :D :
Well, you need to add some electronics to the mix: a pic microcontroller, some mosfets, a few resistors, a few luxeon leds, a heatsink, a difuser and a li-ion battery...
and you get this:
luxeons attached to heatsink and difuser over leds:
from the bottom:
potentiometer is used to adjust the speed of the sweep
without the vase:
vasecolor
and here is a sequence of frames:
If you can view DivX files, here is the complete color sweep (480k)
Hope you all like it
Pablo
Neg2LED
'straya, mate!
Sweet! I made a little similar device some time ago - it uses a single Spider HighFlux RGB LED though. it's embedded in a five-inch acrylic ball, i drilled out a cavity, then filled it with epoxy and pressed the board in - left it overnight, now the entire thing is embedded. I gave it to a friend last year, so no photos :(
it took ~10 seconds to run through all the visible spectrum :p
--neg
sniper
YEAHBUT... What happened to the brush? I had visualized some sort of lighted wand, for cleaning those hard to see areas! Or perhaps a fiber optic treatment of the business end. :wow: Evil Grin.
dcarch8
Nice work!
Let me see what I can do with the plunger. :)
dcarch8
