Yeah, what cratz said about taking them apart. You will destroy a T3/XO3 and most of the Inova lights by trying to pull these apart. But if you use the 'freeze-pop" method it is very easy and works on the X1, XO, XO3, T1, T2, and T3. I've "popped" them all. Here's how:
Take the battery out and fill the body with water (distilled water is best to prevent corrosion) by submerging the flashlight in the water. With the light fully submerged, replace the tailcap tightly. Now put the light in the freezer and wait. When the water freezes, it pushed the bezel out a little bit with no damage. It may take several freezes to get the bezel completely off.
I must say that I did not think of this myself. It was discovered by another CPFer. I couldn't find the old thread and can't remember his name.
I didn't take current measurements on all the lights I disassembled, but the XO3 was drawing less than 400ma from fresh CR123A batteries. I think I figured it was about 600ma going through the emitter.
I still have several in pieces and I've been meaning to put them back together without the regulator and run them direct drive. I think it would be a real contender at 1 amp! I'll get to it one of these days.
