Paul_in_Maryland
Higher-output 9V and 12V lamp assemblies from Wolf Eyes will be available from Pacific Tactical Solutions around the fourth week of Feburary. The lamp assemblies will fit existing Wolf Eyes 9V tactical lights and 12V tactical and turbohead lights:
This should be interesting.
- The $12.95 Raider D26 is a 9V lamp assmbly for Wolf Eyes' tactical-head (36mm) lights (9A/9AX/9H/9HX/9T/9TX). It's rated for 220 lumens with three 123A primary cells, 200 lumens with two 150A lithium-ion cells. The disparity suggests that it's an efficient lamp that causes little voltage sag when used with primaries. (The reverse is true when using the 2.5-amp Surefire P91).
- The $13.95 D36 shares the D26's ratings but fits the 42mm-bezeled 9D/9DX (3x123A), the 45mm-bezeled 9M/9MX (3x123A, not listed at this site), and M90/M90X (4x123A).
- The $10.95 M100 is a 9V lamp rated at 200 lumens, designed for the Wolf Eyes rechargeable M100 Rattlesnake 2.5-inch turbo.
- The $10.95 M100X is a 12V lamp rated at 300 lumens on four 123A primary cells. Designed for the company's nonrechargeable M100X Rattlesnake 2.5-inch turbo, it is not intended to be powered by three lithium-ion cells, but that won't stop someone from trying to find a way to do so, provided a compatible body/head can be found.
