this_is_nascar said:
I won't get into the technical aspects, since that is not my area of expertise. Quick frankly, the amount of light coming out the front of an LOP vs. runtime, when compared to other 1xAAA lights I have/had falls far short of expectations.
For example, the LOP is not producing 5-times the amount of light an Arc-AAA will produce, however is has less than 5-times the runtime of a stock Arc-AAA. I have a Lux-III modded Arc-AAA that produces much more light than any of the (4) LOP's that I've owned and it runs for over 3-hours regulated. That's 3-times longer than the LOP.
Lumens is a tough thing to call. The reflector on the L0P is close to as good as a refector it's size can be for a Luxeon (my opinion of course), but a AAA form factor just doesn't have the diameter needed to get most of the light focused into a beam. So most of the light being produced from the L0P is a floody corona, not a beam like the L1P.
Hey this_is_nascar, you have one of my L0P mods which has the loctite removed from the bezel so you can expose the Lux. If you have a bigger luxeon reflector, you may want to try holding one up to the Lux of the L0P to see what I mean. I did this with the L0P and I was amazed. My modified L0P produced a brighter hotspot than a stock L1P, when I used an L1P reflector on the L0P!
My point here is that if you understand the meaning of lux and lumens, then it's easy to understand how difficult it is to figure out something like efficency of a switcher based soley on lux. Lux is only brightness at one point, it doesn't indicate the lumens being produced.
