The "KT" TurboHead is used by the KT1, KT2 & KT4.
It is generic and can be used with a number of Lamp Assemblies if you power it correctly on the right body.
two-SF123A: N1
three-SF123A: N2, MN15, MN16
four-SF123A: MN60, MN61, N62
one-B65: N4
one-B90: N5
The KT2 reflector is the same used by the shock isolated Millennium TurboHead so the beams of the M3T and M4 are the same as when the KT is used on classic bodies.
Lamp Assemblies with "Nx" such as N1, N2, N3, N4, N5 & N62 were originally designed for 3" diameter extended range TurboHeads "Tx" (T1, T2, T3 etc).
The smaller filaments meant the reflector finish could be finer and more intense beams generated.
Lamp Assemblies with "MNxx" such as MN15, MN16, MN20, MN21, MN60, MN61 are designed for the Millennium TurboHead which requires the outer spring contact to be as long as the inner.
The larger (longer, thicker) filament mean that the reflector finish needs to be more coarse. However, more powerful output can be generated.
The MNxx lamps have no issues that I'm aware of in the "KT" TurboHead.
The N2 should not be used in the M3T or WeaponLights for critical applications because it can result in less than 100% contact under abuse/heavy recoil conditions. The same goes of the N62 in the M4 or WeaponLights.
The MNxx are unlikely to produce perfect beams in the "T" Series 3" diameter TurboHeads because the filaments are too wide/thick in some lamp/reflector combinations.
Al
