[SIZE=+3]
Hi folks,
Finally you will have opportunity to have a convertable flashlight from small to medium or large, rechargeable or primary, extra long run time to brilliant bright pocketable light.
Switch housing is seperated from battery barrel and you can choose any size and form of battery barrel for different use.
A set comes with switch housing with installed switch and O'ring, all following battery tubes, C size tail cap, spring, O'ring, A size tail cap, spring, O'ring and rubber sleeve (for 3C)
No head, bulb battery or charger is included in a set.
1C can be used with lithium ion and Strion bulb for long run.
2C can be used with lithium ion and TL-3/1499 bulb for brilliant choice.
3C can be used with NiMH and Strion bulb for extra long run and rechargeable with stock charger in cradle.
Simply add 1C to 3C for 4 cell operation and so on.
4C can be used with Scorpion bulb for 4 hours run time. Axial or WA1319 with HP head.
5C can be used with TL-3/1499 with standard head or US bulb with HP head
6C can be used with WA1274 and HP head.
4x2/3A also can be used with mentioned 4xNiMH operation in smaller package or use 2x18500 li ion with TL-3/1499 with standard head or US bulb with HP head. For emergency or ocasional use, 3 primary lithium 123 is perfect choice.
5x2/3A can be used with TL-3/1499 with standard head or US bulb with HP head. You can also use 2x18650 in this tube for longer run time.
6x2/3A can be used with WA1274 in HP head or 3x18500 with 11 volt axial bulb in standard head or WA1331 in HP head.
The more you play with this flashlight, the more use you will figure out.
Price:
$140 Black or red set
$160 Grey HA III set NOT AVAILABLE
$40 Extra black or red switch housing (with switch and O'ring)
$50 Extra grey HA III switch housing (with switch and O'ring)
$10 Extra black or red "A" size tail cap
$12 Extra grey HA III "A" size tail cap
$22 Standard black head/reflector with installed Boro lens
$32 Standard red head/reflector with installed Boro lens
$28 Black HP head
$32 Fast charger cradle (for NiMH only)
$18 AC 120V power cord (for NiMH only)
$6 UltraStinger bulb (FOR 2 li ion cell HP MODELS)
$6 TL-3 bulb (FOR 2 li ion cell NON HP MODELS)
$9 CA1499 bulb (FOR 2 li ion cell NON HP MODELS)
With purchase of extra switch housing, you will have 2 bodies with different battery configuration.
Shipping:
$10 to States
$18 internationaly
Please post detail of your order here and paypal note.
Paypal: [email protected]
Please PM for different payment method.
Any comment welcome.
(AVAILABLE)
[/SIZE]Hi folks,
Price:
$28 Black HP head
Shipping:
$10 to States
$18 internationaly
