SMLLRisBTTR said:
According to the Peak website, the Kilimanjaro uses 1 LED. They have 2 models, a hi power at 34/37 CP and an Ultra power at 42/45 CP. Sounds like a lot of light for 8 hrs on a AA cell.
To the best of my knowledge, there is no review of any current Kilimanjaro model on the net. However, for brightness (throw and overall output), the 1 LED Kilimanjaro should be about equal to the 1 LED Matterhorn (which uses the same 5 mm LED at the same current levels, but AAA cells). There is a
Matterhorn 1 LED ultra review at flashlightreviews.com, so it may be possible to compare those numbers to the
Pacific review there. The Kilimanjaro will of course offer longer runtime than the AAA Matterhorn, though. According to
this thread and
this additional post, usable runtime for the 1 LED ultra Kilimanjaro may even be as long as 20-40 hours.
On the other hand, the 1 LED Kilimanjaro models will definitely not offer "a lot of light" in comparison to the Pacific, but will be more useful for walking inside a building in the dark, close range reading, inside a tent, etc. The Pacific uses a high power Luxeon LED inside a reflector which will give you a focused hotspot with much more throw for illuminating something at a distance (230 CP according to Peak), still enough spill to light the way in front of you and probably about twice the overall output. Usable runtime will be somewhere between 5 and 12 hours depending on the type of battery used. So the Pacific is basically between those high power AA lights like the Fenix L1P or L1T (on high) which offer even more output for even shorter runtimes, and the 5 mm LED Kilimanjaro which offers lower output for much longer runtimes.
The 7 LED Kilimanjaro models have considerably more overall output than the 1 LED model at the cost of shorter runtime, but still do not give you as much throw for illuminating something at a distance as the Pacific can due to its reflector.
So it all depends what you want to use the light for.
