Maybe I'm in way over my head, but I've decided to try to build a flashlight using the relatively new
Luxeon
K2 Led. I've started by buying the Led at . It is in the form of a Luxeon
Star. I have done the calculations, and at first I was planning on using a 9V battery, but that would be impractical. It seems that I do not need a driver or resistor if I use 4.5V (The resistance needed was only .33 Ohms, and the Dynamic resistance is .6 Ohms). At first I tried using one of those cartridges for 3 AAA batteries, but it only gave off light equal to that of a 1W, so I had to step it up to 3 D cells. This seems to be able to run the Led at about 1 amp, which is what it is specified for. I was never planning on making a huge flashlight, but it needs to be run on bigger batteries in order to receive the right amount of current. So the final question is how to make a driver, or is it possible to be able to run the K2 on just 3 AAA or AA batteries.
