RGB_LED
Just saw this on LightHound.com... anyone purchase this light yet? Spec's according to the link are as follows - the light looks a lot like a Gladius but only has two levels of output. BIN code is listed as UWOJ (nice) and runtime on high is fairly good with NiMH at 2 hours, 27 minutes, low is 20+ hrs. Price: $290.
http://www.lighthound.com/sales/arcmania_maxlite.htm.
- Quantity/ Battery type - single/AA battery, alkaline, NiMH, lithium
- Battery life (High):
- Duracell alkaline - 65 minutes on high.
- 2500mAh rechargeable NiMH - 2 hours, 27 minutes (147 minutes.) Ending voltage, voltage protection enabled at 1.0 volts.
- Battery life (low) - 2500 NiMH - 20 hours, 50 minutes (1250 minutes.) Ending voltage = 1.02 volts.
- LED type - 1 x UW0J Luxeon III
- Estimated emitter life - 100,000 hours
- Body Color - Bare aluminum (finished product- natural hard anodize)
- Window Material - Glass
- Reflector - Custom made, 27mm
- Electronics - MJ-16, voltage boost, 1.2 to 1.8 volts
- Switch - On/off, two-brightness, twist switch in tail cap
- Body Material - 6061-T6 hardened aluminum
- Finish - bare (finished product- natural color hard anodize)
- Seal Type - Silicon O-Rings throughout
- Depth rating - Unknown, waterproof
- Size (length, diameter f/r) -112mm long, 32mm/ 21mm
- Weight (With Batteries) - 119g (4.2 oz)
- Accessories: None
- Manufactured - US
- Other- Two level brightness, Surefire E-series/Aleph tail cap compatible, body made of solid billet aluminum, limited run. Over discharge protection for rechargeable battery.
