SaturnNyne,
Hrmm that's weird. I just tried the unscrew tailcap thing with my 2D ROP which has the stock tube, tailcap, spring and a modamag 6aa to 2D carrier. It turned the light off after the slightest twist of the tailcap.
As i understand it, the area completing the circuit in regards to the tailcap and body is the end of the body (where there is no anodising) and the area that flares out after the tailcap thread ends (there is also no anodising here, and there are uniform grooves cut around the circumference). If the un-anodised part of the tailcap is not touching the un-anodised end of the tube...the circuit is not closed and the lamp will not fire regardless of the switch being on or off. Anodising is a very poor conductor of electricity iirc.
The threads on all my Maglites are anodised (both tailcap and body). Perhaps i got different ones to you ? I did buy the host in Australia if that makes any difference o.0
And thankyou (re. avatar
