cue003 said:Any pics of the Photon King you reference? I don't think I have any idea of what it looks like.
Thanks
Curtis
cue003 said:Wow, not sure but on my screen the post above made by me AFTER reading about more throw actually appears FIRST.
Interesting.
Curtis
xpitxbullx said:I just put a Philips 5761 lamp in mine. WOW!!! Throws better than my Mag85.
Jeff
Protaeus said:get a larger reflector something along the lines of 6 inches ought to do the trick.
maverick said:Jeff, could you tell me what kind of mod I would need for that?
Protaeus said:get a larger reflector something along the lines of 6 inches ought to do the trick. Or you could go to an optics place and get them to make you a fat optic to strap ontop of the M6
BTW, what are you trying to spot?!?!?!? My M4-6 has enough through for all of my needs and Ive used it for spotting people across football fields.
xpitxbullx said:He also has a link to where you can get the 5761 bulbs. In the M6, that bulb is pushing over 1300 lumens at the bulb.
COOL!!!!
Jeff
dizzy said:In the spec list of that bulb, it say it is 765 Lumens @ 6 volts. Does the M6 reflector make this bulb brighter or is it because it is driven harder than 6 volts?
cue003 said:What happens if you fire up the 5671 bulb with the stock battery configuration? Will it blow?
Curtis
