Alephs,TB tubes, bezels, Maxlite II, LC/LH boards, FM & Mac M*g mods, VIP, Tvodrd NLS
I am selling some spares. I am interested in trades or offers. I will be adding to this thread so please check back for updates. Items in bold are still available. This is sort of a continuation of this thread.
1. Black Maxlite II pre-order spot #56 with clicky and single stage. I'm asking what I paid $245 PENDING
2. NAT Maxlite 2 stage twisty #58. This mint condition light comes with the S bin emitter which I believe was rare with this build. You can convert this light to a clicky with a pre-order by TnC going on now. Lighthound is selling these for $297 including shipping. $245 SOLD
3. Mint modded UX1J HD45. This light started as a joker TWOJ and was modded by milkyspit to a non joker UXIJ for superior throw and ouput. This HD45 also works with 18650s and flat top cells unlike most HD45s. A few marks were made on the edge of the lens when this brand new light was modded and these show on the edge of the beam. I'm selling well below my cost at $240 SOLD
4. New unused black HA Aleph 1x123 tube. $37 TRADED
5. New unused black HA Aleph 1x123 tube. $37 SOLD
6. New unused black HA Aleph 1x123 tube. $37 SOLD
7. New unused black CR2 tube. $37 SOLD
8. New unused black CR2 tube. $37 SOLD
9. New unused black 1.5x123 or 2xCR2 tube. $27 SOLD
10. Ti TnC proto Ti 27mm bezel ring $55 SOLD
11. Aluminum TnC Proto 27mm bezel ring $30 SOLD
12. Unused grey EXTN-36 for M6-R by Petrev. $75 SOLD
13. Unused grey EXTN-36 for M6-R by Petrev. $75 SOLD
14. VIP in excellent condition includes the kings crown tail, 123 tube, and the standard head w/reflector and optic $135 PENDING
15. Special Edition VIP "smoothie" upgraded with a UXIJ, only one of five or six made. These VIPs were built without the knurling and are much easier to handle and nicer to hold IMO. The light has two pin sized spots missing ano on the module, but the light hasn't been used otherwise. I'm including a king's crown tail switch and the standard head with reflector and optic. The light in the picture (lousy picture) has a Halibut tail and BH that I am now including. $235 SOLD
16. VIP pocket clip $15
17. VIP 2 AA tube in mint condition $55 PENDING
18. New unused Lioncub boards $30 for (1) and $25 for each additional board. These boards will work in the Lioncub, Lionheart and Chameleon. These boards are a V2 firmware upgrade for the Lionhearts and a PWM solution for the chameleon for higher output at DD than the chameleon (depending on the Vf of the LED).
19. Lioncub pocket clip $15 SOLD
20.Lioncub pocket clip $15
21. Silver nFlex WYOS Mag2D on a 'D' heatsink bored to accept 8 AA of any width with included ModAMag 2D to 8AA adapter. The mag switch has been modded for momentary activation. Comes with a LOP Aluminum reflector and it includes a UCL. The lights shows some minor wear from light use. $160
22. TranquilityBase 18650 NAT E series tube. Some don't realize TB manually lathes his items and the workmanship is superb. On this one though the HA is lighter on one side and not otherwise perfect. $75 SOLD
23. Icarus FM 1.5 WWOS M*g. I recently received this beautiful light. It is a red FM 1.5 tri-bore body that came with the 700L series. Icarus put blue glow powder around the emitter, built a cage for the N-Flex board, modded the switch for momentary and cut the cam off the M*g reflector. It comes with a UCL window and a FM battery holder for 3x 17670 li-ions cells for extremely long run times on the 5 level Nflex light with 1000ma on high for tremendous output. You don't see these sell often and I don't know why I'm selling except I don't have a use right now. I'm asking what I think I paid. $255 SOLD
24. FF2 T bin madmax sammie (only). $45
25. Red FM3V Elephant. This new unused light was purchased at a large premium from the builder long after the run was over. The light comes with two extension tubes, the extended tail cap and (3) 3x18650 battery carriers for many bulb configurations running from 3.6v to 10.8v. $575 SOLD
26. Black FM3H. SOLD
27. Red FM 1D with 4x 14500 parallel holder with charger jack. This beautiful light is new unused and would make a great setup for LEDs or 3.6v bulbs. Stock lens, bulb and reflector. $150 SOLD
28. Mint chrome PD. This was once part of Don's own stash. It has a UX1J, tritium piston, Ti clip and bezel that Don polished. It has the standard drive levels. There were only 40 made. $575 SOLD
I have the below TnC parts listed at TnC Forums with pictures and these might sell there first. The first to post in either forum gets the part.
29. TnC SF NAT 27mm head. These heads work with the TnC SF system only and include the Mcgizmo 27L reflector, a mineral lens and o-ring. $59.50 SOLD
30. TnC SF NAT 27mm head. These heads work with the TnC SF system only and include the Mcgizmo 27L reflector, a mineral lens and o-ring. $59.50 SOLD
31. TnC SF NAT 27mm head. These heads work with the TnC SF system only and include the Mcgizmo 27L reflector, a mineral lens and o-ring. $59.50 SOLD
32. TnC SF NAT 27mm head. These heads work with the TnC SF system only and include the Mcgizmo 27L reflector, a mineral lens and o-ring. $59.50 SOLD
33. FM 1xAA HA gun silver mini mini with head bored for 20mm reflectors. $80 SOLD
34. Mac finned and grooved pewter 2xAA mini mag. $40 SOLD
35. Mac finned and grooved pewter 2XAA mini mag with a metal reflector and glass lens. It also comes with a TL-3 bulb, (2) AA sized li-ions, and a cermic base for a mini hotwire setup, however the copper leads broke off the base in transit. This might be a good deal for someone who can replace the copper leads or who has a spare working ceramic holder. $60
35. FM Spiral Gun Metal HA M*g 85. Comes with stock lens, bulb, reflector and a 9x4/5A FM rechargeable battery holder that charges through the tail cap. $150
36. FM Chromed, finned and grooved 8xAA mod. ON HOLD
37. FM3V Chrome 3" head with two chrome tube extensions and a deep tail cap. Includes 3x3X18650 holders. PENDING
38. Mac "Torch". Red with fluted head, 12xIB1400 cells and battery holder. There are a few 'small' scratches on the knurling and the light was charged about 10 times. This is probably my favorite bright flood light. $275
39. Mac 1150/550 lumen ROP mod. This is 'the' ROP mod IMO and is a complete custom light including charger and 6xA battery pack. Also with a few small scratches to the anodizing with about 10 charges on the light. $260
40. Pewter SD Mag with fluted head and mac's tail switch. This a flupic UX1J run on a 4xAA holder with a UCL lens. The tube has a scratch, otherwise this is a light saber driving the flupic and LED hard on burst or at low levels on low with my program:
Of course I am also selling the TnC Lava Lamp and other lights/parts on the TnC Online Store.
For all orders over $25; shipping usps conus with delivery confirmation included. Insurance is extra if requested. Interntional orders' shipping costs are extra. I won't be responsible for loss. Paypal or US Postal Money Orders accepted, CC paypal please add 4%. First to post an unconditional "I'll take it" in this thread gets priority. After posting please email for payment and shipping details in the email in my user profile. Please email if you have a proposed trade. I'm willing to pay for upgrades and accept partial payment and lights in trade as well. Thanks for Looking.
User Mode 1: burst> level 1> tactical strobe> Level 2> 3 second beacon>15 second beacon>SOS> set mode
User Mode 2: set level > set strobe >set mode, 800ms
The second interface goes back to the first after 800ms to make it simple and to make it harder to get lost. Milkyspit built this for me and I probably have over $250 in the light. Asking $225
Below are new and unused Aleph LEs. These LEs will be sold to buyers of the Alephs lights below first and then available as parts:
41. UX1J flupic Aleph LE built by Icarus with the UI listed above. $95
42. UX1J flupic Aleph LE built by Icarus wtih the UI below $95
busrt> level 1> strobe> Level 2> SOS> OFF > SET LEVEL > SET STROBE at 800ms.
43. UX1J NG1000 Aleph LE built by Icarus. $95
44. Red F4GR NG1000 Aleph LE built by Icarus. $95
45. Royal Blue Q5KY NG1000 Aleph LE built by Icarus. $95
46. Golden Aleph swirl A2, 1.5 tube and flat top two stage tail cap. On Hold
47. Black and green Aleph swirl 2x123 tube and trim two stage tail cap with a choice of heads. On Hold
48. Chrome A3. On Hold
49. Black Aleph A3 complete. Head is only tested but it came new with a few spots of missing anodizing. 2x123 tube and Mclicky tail included. Pic shows the head and the missing ano, but the tube and tail in pic are not included. Please pick an LE between #41 and #45. $240
50. Black Aleph A1 complete, 1.5x 123 tube, McClicky tail switch. The had has a hard to notice flat spot on the rim, although no anodizing is missing and bezels thread in fine. Bezel in pic is not included. Please pick an LE between #41 and #45. $230
51. Icarus Black QL-A3 driving 4xUX1J LEDs in 4x McR-20 reflectors at 700ma each for 340-460 lumens at the LEDs! 2x 18500 TB dark NAT body plus black Mc2Es standard tail. On Hold
52. Mc2Es trim black tail. $75
53. Mc2Es SFT black chopped flat top tail. $75
54. Mc2Es standard bare tail without the tripod holes (rare). Pic showed on tube (not included on #56). On Hold
55. Mc2Es standard NAT (dark) tail. $75
56. TB 3x123 bare aluminum E series tube. Tube does not include tail in pic. TB's tubes are manually lathed and are beautiful. $85
57. TB 1x18650 black tube E series tube. Pic on # 49 shows the tube. $85
58. TB 2x 18650 black tube E series head and C series tail with Mc2Es two stage switch in C tail. C tail has a nick. Head is not included. On Hold
59. Bare aluminum A1 bezel ring (standard issue). $15
60. Bare aluminum PD-A2 bezel ring (standard issue). $15
61. Original straight Ti PD clip w/screws. $20
62. McGizmo 27mm Ti bezel. $59
63. McGizmo 20mm Ti bezel polished. $39
64. McGizmo 20mm Ti bezel. $39
65. Shoppe 27mm Ti bezel. These bezels have sharp ends and are not high quality as they were sold. You may need to sand the threads to make them fit. $25
66. Shoppe 27mm Ti bezel. These bezels have sharp ends and are not high quality as they were sold. You may need to sand the threads to make them fit. $25
67. PEU 20mm stainless bezel with slots for tritium. $29
68. PEU 20mm stainless bezel with slots for tritium. $29
69. PEU 20mm stainless bezel with slots for tritium. $29
70. 3x green Gregw tritium vials for PEU's 20mm bezels etc. $20
71. 3x green Gregw tritium vials for PEU's 20mm bezels etc. $20
72. 3x blue Gregw tritium vials for PEU's 20mm bezels etc. $20
73. 3x red Gregw tritium vials for PEU's 20mm bezels etc. $20
In addition I have more bezels listed on my TnC Online Store.
I am also offering a Tvodrd light (known by many as Larry Lights). This is a green NLS. These are rare and special lights. Please send a PM to my profile with any offers. I've lowered the price to $450.
