Frank_Zuccarini
- Joined
- May 16, 2006
- Messages
- 153
After searching the CPF, it is clear that the MN11 (HOLA for the M3) and the MN16 (HOLA for the M3T) use the same bulb. It is equally clear that the bases of these two bulbs are different, in that the base of the MN16 is longer than the base of the MN11.
This information indicates that, while there will be no current or amperage issues resulting from using the MN11 in the M3T. However, it is equally clear that the bulb of the MN11 LA will not extend as far into the reflector on the M3T as will the bulb of the MN16.
My questions, for those with the experience to answer or even speculate, are......If I use a MN11 in a M3T:
1) How will this affect beam quality?
2) How will this affect heat dissipation?
3) Will question 2 above affect bulb or flashlight life expectancy?
Thanks for your help........................Frank
