AndyTiedye
A number of years back, we bought a number of these cheap incan "torchiere" lamps
we loved them until we got the electric bill.
Since we haven't been using them in some time,
I thought I'd try putting some Cree XR-E's in one.
The pole is in sections -- the bottom section makes a nice battery tube for 8 D cells:
I glued the XR-E's directly to the aluminum reflector with Arctic Alumina.
I cut all 4 corners on all but the most negative of the LEDs because they
are in series.
Currently direct drive, and the LEDs are barely coasting along at 400ma
with a set of partly-charged NiMH's. Obviously room for improvement
here. What sort of controller would work best for this? Continuously
variable would be a big plus.
This torchiere has since been updated with a Fatman controller and 1 more Cree XR-E LED. It is dimmable by means of a 50k audio taper
potentiometer (mounted in the original dimmer hole) connected to the Fatman.
are in series.
