Bigmark408
I went to fire up my surefire M6 and the bulb exploded inside the head.......has any one had that happen to them.....and if so why?
bigmark408 said:I went to fire up my surefire M6 and the bulb exploded inside the head.......has any one had that happen to them.....and if so why?
Diesel_Bomber said:You might also change the thread title to "Surefire M6 Bulb Explosion." I thought it was the entire flashlight; catastrophic failure of the batteries or some such thing.
:buddies:
nobody said:You didn't handle the glass lamp with your fingers before it blew, did you? (Doing so would be a bad idea.)
kakster said:My 3 "old style" MN20s also have black bases. Surefire stopped doing coloured bases quite a while ago.
OutdoorIdiot said:Damn. I wonder if there is a definite way to tell them apart, then?
js has counted a couple more turns in the filament of the newer ones, but I would guess that's not much use once the bulb has exploded!
nobody said:You didn't handle the glass lamp with your fingers before it blew, did you? (Doing so would be a bad idea.) Did the popped bulb trash the reflective coating inside the head? Got pics?
