ab
Hi everyone,
My EDC is an ARC AAA LE. I recently got an AAA Standard v3.1 for backup duty. The Standard is brand new production and was picked from a group of nine as having the best/brightest/etc. beam.
When I lit up my LE and the Standard together I was a little disappointed by the Standard and quite pleased with the LE.
Have a look and see why:
Although it is hard to tell in the photo the lights are approximately the same brightness, with a slight edge going to the Standard. My digital camera is quite a bit more sensitive to the Standard's bluer light than the warmer output from the LE. Also that little blue spot in the LE beam's center is not nearly so noticeable when just looking at it.
The big disappointment however is not the brightness at all but rather the unevenness in the Standard's beam and the blotchy and very angry blue artifacts in the central hotspot.
You can see this a little clearer in this closer look at the just the Standard's beam:
Yuck!
Hmmm... I had expected the Standard to be brighter and whiter than this. I certainly won't be replacing the LE on my keychain with the Standard!
Is this typical with the Standards?
A.
Yuck!
A.
