I'm the guy who initially opined that the 1185 is a better bulb than the ROP HI.
Here's are a few reasons
1) The ROP bulb tends to be yellowish (too low color temp) for my taste on 6 NiMHs. Doesn't matter if its Ds or AAs or who the cell maker is. That means you really need to run a ROP HI on 7 NiMHs for my taste.
2) Problem is that when you run it on 7, it is quite prone to instaflash on fresh cells. I'm not much for the silliness of "resting" stuff - I rarely plan 8 hrs ahead about using a battery powered device and may grab "hot" cells to run anything from cameras and strobes to flashlights. (I've got about a dozen 110 outlets occupied with chargers at my charger station and have capability for essentially all common cylindrical NiMHs and lithiums in many varieties including Cs and most of the common Sony camera and camcorder batteries as well as other brands)
3) If you run the ROP on a 6 NiMH cell equivalent in C-Lions (a pair) and compare it to a Welch Allyn 1111, you will see that the 1111 is whiter and generally has a better formed beam. (The 2C 1111 with an AW starter and a MOP/UCL is a very nice and compact light.) The 1185 is basically an up-voltage and brighter 1111 and otherwise very similar.
4) In the 3 cell size (3C-Lions in a C light or 9AA in a D light), the 1185 is similarly white, brighter than a ROP on 7, so why would one want to fabricate a couple dummy cells for 3D light to run a ROP in that size when you could stick 3 C Lions in the tube or just buy a smaller 3C light? A the 3C Lion 1185 is compact and has a passable balance of power/runtime for its size. Its got good color and is not prone to instaflash, at least in my hands.
5) I see no good reason to use a potted bulb that can run as hot as a ROP, 1111, or 1185, etc. The bipin is better choice for high temps both for the bulb and socket design.
C Lions are more convenient than sets of AA NiMHs as long as you are within the amp limits of protected C cells. They hold a charge a lot longer, you can charge them in or out of holders (you can get C holders at RS and daisy chain them on a 777 charger or multiple other similar alternatives) and lights just like AAs, etc.
