iTorch
Hi there, first let me say Hi, as I am brand new and this is my first post.
Second let me say I am from New Zealand, this means not very many people selling torches, not many shops to go to to check out torches , so main aspect is web, and hopefully this forum to get ideas.
Ok, now thats out of the way can I ask for some definitions and general stuff, lux and lumens? throw? incandescent and LED? i assume throw is how far the light will travel usefully, LED light emmiting diode, Incan-old fashioned fillament. Not sure about the lux and lumns, is 2 lumens twice as bright as one? and is 10 lumens 10 x as bright as 1 or does the scale work differently.
Now I own a big old 4D maglight (in the car-not sure if batts flat or not), a mini mag 2AA, and a petzel headlamp 4AA, and a tiny led black diamond headlamp. the LED is the only led, others are, er, bulb thingies.
I carry my mini mag everywhere in a little bag that holds my iPod, keys wallet, sunglasses, first aid kit, leatherman, cell phone, etc etc.
Now I want to retire the Mini mag to my scooter tool kit, to use with that.
Which means I want to get an every day carry torch, and I was thinking of an LED, in particular i was thinking of a fenix, prob P1D, or P2D or P3D or T1-all Q5.
Why these, well they seem reasonably cheap, good lights, bright, good quality and fairly small. Also there are a couple of online importers in NZ.
My requirement is small-so that I always have it with me when needed, strong-take abuse (may need to hit someone with it in emergency(in my fist)) or drop it, bright-like to be able to see when needed, multi level-not give too much away at other times, able to be dunked-NZ is not a desert.
Should be able to be used as ageuine torch if hesdlamp fails, and as a back up when it does not fail, batts should last a while, do not care about type. Will these fit the criteria or are there better types, should I avoid fenix, or LED or go for them, should I get a big one like the T1, or will the P1D suit me fine, or should I avoid fenix and get something different again, batteries i do not care about type, size must be same or smaller than mini mag, and what is the deal with lumens and lux?
Thanks in advance for help advice.
Shelley
Shelley
