Tao
- Joined
- Apr 19, 2008
- Messages
- 19
Hi all.
I've been reading here and lurking for awhile, and frankly, I'm overwhelmed with all of the information.
Instead of guess, and probably end up wasting money, I figured I'll ask, just to make sure I get what I'm looking for.
Basically, I need a replacement for my xenon scorpion that I can carry with me on the ambulance. It'll be used to light up and read street signs from less than 30 yards, and used to investigate bumps in the night at no more than in-the-house ranges.
I'll throw out this wishlist, in the hopes there is a light out there that fits:
Ugh. So this is where I'm simply overwhelmed by all the choices and tweaks and models and specs.
Any suggestions, but especially models, or things to look for, would be greatly appreciated.
Thanks!
- Brighter than the xenon scorpion.
- Spotlight type beam. I need all the light on one bright point right away.
- The same rough size as the scorpion, because it'll be in my cargo pocket most of the time.
- LED so I can't blow bulbs.
- Momentary with some pressure, and then stays on with a click like the scorpion. If I need light, I need all the light it can give me, right now, with the ability to use the momentary for just little bursts.
- Last but not least, it has to be compatible with these rechargeable CR123A batteries from DX. The info said compatible with regular 123A batteries, but I found out that wasn't true when I fried the bulbs in my xenon scorpion, because of the higher voltage. I like CR123A lights, but refuse to buy any more non-rechargeables.
Thanks!
